Submitted by Joe on Thu, 05/12/2011 - 07:45
I would like to know if it is possible to use text strings as row column headers in map files for table lookups.
Submitted by Anders89 on Thu, 05/12/2011 - 07:48.
Yes, for 1D maps you can select the 'Use First Row as Pin Labels' option. The first row must be a comma separated list of strings, then the output pins will take on the names from the row: col1 -> pin1, col2 -> pin2, etc.
