I want to create a Lump Mass of a stack of Iron Ore over an area (the stack is in the form of a cone).
Thought of creating that stack with SPH elements. Is it right approach to this problem?
If Yes, what should be the PROP of the SPH (such as: qa, qb, order etc.) and what should be the MAT (Material law and respective parameters)
If No, what other alternative available for this.
Thanking You.
rgrds,
Pritam
