Hello at all,
i would like to know if there are any possibilities for additional Outputs after a fatigue SN analysis. The only output i can use is the model and a scale showing the steps and the damage/life of the models elements. Is it possible to show any stresses or graphs where the time an the damage could be seen ? The only plot i can generate is a little perplexing, because of the time scale which is confusing me an the dots. Can anybody explain the left scale named damage (2D) to me ? what do the numbers mean ?
I would be very pleased if there is a way of showing more results of the fatigue analysis for example using some additional control cards.
greetings
Christian
