How to solder joints in Hypermesh ?
I want to automatically connect many points in two lines
thanks
Connect two entities . I'm sorry I write a wrong word.
You can use rigid elements.Can you share screenshot of where you want to connect two entities?
Please use HW Desktop 2017.1 or latest patch 2017.1.Refer below post for similar query.
The solder joints are made correct is the prime importance in any electronics construction. A good solder joint will have a shiny finish and also having too much solder.
