Hi everybody,
I created a tube and now I would like to renumber the circumferencial nodes in a specific way. (picture attached)
To find and select the node where I want to start my renumbering I can take the 'hm_getclosestnode' command.
This will work pretty good, but I don't know the command which I have to use to select the other circumferencial nodes ...
Should be something like this:
1. automatically select node on position 1
1.2. renumber it starting with ID=1
1.3 automatically select the next node (on position 2) and renumber it with ID=2 (and so one with increment 1)
2. after first loop automatically select node on position 201 and renumber the node with 201 and so on with inc. 1
thanks in advance
0815
