i´m trying to do a topology optimization of a motorhousing of an ebike. there already is a working model of this ebike.
i imported my design space as a .step file (shown in orange in the picture) and created new contact surfaces where the design space is attached to the pipe recievers and edited the old contacts by changing the old vs the new contact surface. There was no node to node contact before.
After that i organized the red elems of my design space to the non design space (2 different comps) and assigned both their individual property.
When i try to run the optimization the process is stopped by error # 312. I looked up many topics regarding this topic but couldn´t find an answer which helped in my case.
The compliance is always too large which means by my understanding that the model 'flys away'. So there has to be a issue with the boundary conditions i think. In every selected loadstep my boundary conditions (SPC´s) are assigned.
Which means in my understanding the problem has to be ether the connection between the design and non-design space or the connection between the design space and the rest of the model but i cant fix it.
Do you have any advice in this case?
