Hi, run the tensile test using law 2.
Analysis running properly but at the end it is stopped with message 'Normal Termination'.
After observing out file,instead of showing the cycle number it showing ******* after cycle no.9999900.
Also as analysis running there is rupture of elements.
Suggest the solution for the same.
Thank You.
