sometimes I have to run multiple jobs through the night,what should i do to run them one by one,a dos command?
PFA screenshot from help for submitting multiple solver runs.
thanks,Rahul
I had tried and it works when the fem files are all in the same path,and I can not choose them in the same time when those fem files are in different path,is that a operational problem?
Please refer the attached pdf from help.
Write a script to do this task.
Sometimes I have to run multiple run through the night,what should i do to run them one by one,in LS-Dyna?
Please contact LS Dyna support for this query.
