I am new to SimLab.
When I run a simple parasitic extraction from a small piece of PCB, the solver runs for a long time.
At first, it was due to an error in my assembly. The solver ran for hours and occupied all the RAM I allocated. I kept increasing the RAM from 8GB up to 62GB. But the result won't come out.
I kept killing the solution and make changes to my assembly.
Eventually, I got the assembly correct and the result correct. But even with the correct assembly, it still takes more than 1/2 hour to get the result.
During that long time, I just waited there.
Has no one had similar experience? Or there is a way to know the estimated solve time or a way get an error message?
Sincerely,
Rhonda
