I have to model a pipe using shell elements full of LOX (Liquid oxygen) which is at 20K surrounded by ambient temp of 293K. Please help me how to best solve this..
Hi Arjen
This tutorial deals with similar condition as you have. please check whether this helps.
https://altairuniversity.com/learning-library/tutorial-thermal-analysis-heat-transfer/
Thanks
Hi Pranav,
In the tutorial, is the engine block made of solid elements or shell elements? I see in the .hm file that the property assigned to the elements are thru PSHELL card, but the entire engine block looks like it has been meshed with solid elements,
Can we assign PSHELL card to solid elements? And how to create interface for shell elements?
Since you are considering the heat convection across the wall of the pipe, you have to model it with solid elements with solid property.
Have a look at this tutorial too from OptiStruct help.
This is much more similar to your case.
I had referred to the tutorial OS-T: 1085 before, but the problem is I have to use shell elements, not solid elems to model the pipe (thickness 2mm). Also, Can you please explain how In the engine block .hm file you sent before, solid elements are assigned PSHELL properties? Is this the solution for my case?
Its recommended to use solid element for the conditions you want. However i will check and tell you if any alternatives there.
I checked the file. Its just named as Pshell, but the property assigned for solid elements are Psolid only.
I had not noticed the PSOLID card entry, thank you for clearing it up. Is it possible to use TREF in the MAT1 card to give an initial ambient temperature to the pipe material(Steel) and then give temperature load of 20K using TEMPD?
Thank you
Could you please share .fem file which you are running at your end?
You can request free eBook on OptiStruct Thermal Analysis using below link.
https://altairuniversity.com/free-ebook-thermal-analysis-with-optistruct/
