how can I acces the time step value of the current simulation step to calculate a value for the current flowing through the coils in a transient magnetic simulation?
Are ther any examples coverint the topic?
Thanks
Carl
You get the ‘time’ variable form the editor of equation. For example when you try to create an I/O parameter, select ‘formula’ as type of I/O. Select (F()), a new window opens right there is the parameter ‘Time’. About the example, from Flux supervisor you can open the IPM motor (case with constant speed).
Best regards.
