I want to contrain a model, but to make sure that the effect of the constraints, don't influence the values. I'm trying to use an RBE3-element. This would spread the effect of the constraint and decrease high stress concentrations.
However when I try to constrain the RBE3- elements in their dependent node, I get an error message explaining that there are conflicts with the dofs for the RBE3-elements.
Is there a way to solve this problem?
Kind regards
