Hello to all,
I have a little problem with the Domain Decomposition Method and calculating on the cluster. I get the ERROR # 3413 which says, that non-static analysis is not supported. But I am calculating nonlinear quasi static and the documentation says that this case is supported by optistruct.
My approaches for the fault are:
- Wrong DOF of some parts and the parts are flying away but this should not bother the solver
-The documentation says: 'DDM allows you to run a single subcase of static analysis and/or optimization with multiple processors in either Shared Memory Processing (SMP) or Distributed Memory Processing (DMP) cluster computers.' I have more than one subcase
Has anyone an Idea what optisatruct is saying to me with non-static analysis?
