Hai,
I would like to know which are all the parameters that is important while doing linear static analysis with plastic part.
For linear static analysis , Young's Modulus , poisson ratio and density would work form material properties point of view.
hai gopal,
thanks for the feedback, but again I have defined plastic material properties so I have considered flexural modulus as youngs modulus that is right know. if yes then I am getting same stress value even after changing youngs modulus value. please suggest.
