Hello HyperWork users
I need to model an impact with a sandbag (non rigid impactor)
have you an idea or any proposition how can i do it?
thank you.
Hi Mohamed,
You can model this using SPH method. Once the surface for the sandbag is created you can fill the same with SPH particles and can run the simulation.
We have an example file on SPH model, Example-22, Ditching using SPH and recommend you to go through the same.
thank you
i try to test it and i'll inform you.
