Dear All,
I want to find tonnage required to form the product as follows.
Is it possible in Hyper form or should i go for Radioss?
HyperForm. HF-0150: Quick Setup
HF-1000: One-Step Stamping Simulation
Thanks, prakash.
I'll go through the mentioned tutorial.
Dear Prakash,
As you see in the image attached above,
I have punch, blank and rubber supported on steel plate.
I dont have die.
how can I model the setup.
Hi Ganesh,
I think Die is needed to define the shape for the blank.
