Hi All,
I'm trying to import a component which is modeled as a solid is getting imported as surfaces.
Can anyone tell me how to fix this to importing it as solid?
Thanks in advance.
Regards, Vignesh V.
Hi VigneshKPV,
Please can you share the model?
Thank you
Can you share your FTP link?
https://ftin.india.altair.com:8443/filedrop/~osKE8Q
File Shared. Thanks in advance.
There is some defect in the model (Shown in below image). Therefore, you are not able to import the solid as it is in HyperMesh.
So, you perform equivalence of surfaces and go to solids panel and create bounding surfaces (shown below). Your solid model will be created.
Thanks Premanand!!!
We will try this out and get back to you.
Is you issue solved?
