Optistruct No forces applied but no zero displacement found
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
Hi everybody,
I was running a test with optistruct using two simple cubes. They are both fixed at opposite ends. Their faces are separated by 0.1 mm and can, if pushed, become engaged in a contact (type SLIDE).
Type of analysis: nonlinear quasistatic.
Issue: Even if I fixed both cubes at their bases and there is no applied force and no contact is engaged (shcdist=0.001 and the solver warns me that no contact elements have been defined during the analysis), the cubes translate of 2 mm as if they are moving like rigid bodies.
I have already tried to constrain some more nodes, to no avail.
Any explanation for this thing by anyone?
Thank you in advance.
Find attached my .fem file to check
  • Nachiket Kadu_22143
    Nachiket Kadu_22143 Altair Community Member
    edited June 2018
    Hi everybody,
    Hi @Matteo
    You gave displacement of 2 mm in x-direction in SPC contraints. Kindly make it zero.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Thank you!
    How did I end up not noticing it! Thank you very much :)
