INTERNAL PROGRAMMING ERROR # 8016
Hi guys,
I'm doing a shape optimization on some elements of a 2D Pshell and a size optimization of the shell with optistructoptions : -nt=8 -ln=12000 and i've got an error at the end of the iteration 0 :
**** Error 8016 in datamr() during 'expand' operation.
Data block name 'ielmlstsol'.
Current memory allocation 2864 MB,
Unused memory 2510 MB,
Number of blocks: 576 used, 22 free.
Expanding from 1 MB to 23 MB
Need at least 22 MB free (1 MB more than allocated).
*** INTERNAL PROGRAMMING ERROR # 8020 ***
Failed database modify command: Expanding array ielmlstsol.'
* DATAMANAGER ERROR in subroutine 'EXPAND'.
Here is the .out file if needed
Thanks in advance,
Frederic.
Hi @Frederic
Can you update your HyperWorks solvers to the latest and check if that helps?
0 -
I currently use the OptiStruct Version 2017.2.0.13. isn't it the last version? If not i will ask to my IT service for an update but it can take some time. I'll back to you when it's done. Thank you for your quick answer.
Frederic.
0 -
A similar error with nonlinear case is reported with 2017.2 and was fixed in 2017.2.2
Please update and check if that helps...
