Hi all,
I am currently using Optistruct to optimize the geometry for a bellcrank for a Formula Student suspension system. For optimization purposes, I modelled the worst case scenario (i.e. bellcrank blocks and all in-plane forces go through it). As constraints, I constrained the X-movement of the shock point (top hole) and only allowed Z rotation at the hinge point, applying a load (split into X and Y components) at the third point (bottom hole). Applied 'Volume Fraction' as response as well as an upper stress limit and minimum volume as the objective. As I run the optimization,the material turns 'foamy' and disappears completely as I change the ISO value (i.e. it does not give me any geometry, as the material just disappears as a whole).
Has anyone experienced this issue before or have any ideas how this could be fixed?
Thanks!
Adam
