I have a couple of questions regarding friction modelling in RADIOSS:
- Is it possible to define different values of friction for different parts inside the same contact? In LS-DYNA this can be done by using the *DEFINE_FRICTION card, but I have not managed to find the equivalent for RADIOSS. In this way we avoid defining different contacts for each part with a different friction.
- Is it possible to make friction inside a contact different in two principal directions? In LS-DYNA this could be done through the ORTHO_FRICTION option in the contacts.
Many thanks in advance
Best Regards,
Adrian
