Can I optimize the moment of inertia of geometry by using topology Optimization?
if it can, what kinds of loadstep or load Collector need?
Hi
loadstep and loadcol depend on your structure. I think you will need to set a response type 'inertia'
Really thank you for reply...
When I just want to optimize geometry, I don't know how can I set up loadstep or loadcol... (There are no load or distortion..)
did you try running it without load?
I think just constraint is neccessary
Hi @G. U. Jang
You can use inertia relief with IREL= -2 to automatically provide constraints (if you are not sure about the constraints) and use the same for optimization.
