Hi experts,
I'm facing a terible issue in HW CFD 2021.
This issue is related to "Surface Mornitor" in the solution tab.
Below is my example, this one is a manifold from our tutorial:
You can see there is a yellow surface inside the pipe.
I created this in order to test on the "surface monitor" function & it is assigned with "default wall" type.
However, the massflux on this "surface output" is Zero (0)
>> as my understanding, this "surface output" is calculating the sum of the mass flux on both 2 sides of the interfaces, while it should only to take into account for 1 side.
Below is my plot from log file, the mass flux on the 3rd outlet is exist, but on the interface is Zero
The model is attached. Please help me to find the solution for this!
Thank you very much!
