Initial Penetrations in the model
Altair Forum User
Altair Forum User
I am using hyper crash version 14 . In my model I found some initial penetrations and I removed them all by depenetrating auto option. However when I load the model again it is showing penetrations again. Is there any way to get rid of it??
Thank you.
  • Altair Forum User
    Altair Forum User
    edited January 2017
    Hi Raghav,
    Ensure that penetrations from all the defined contact interfaces are removed.Also, provide correct parameters for the defined contacts.
    If you still face trouble, please share the model file.
  • gopal_rathore
    gopal_rathore Altair Community Member
    edited January 2017
    After using depenetrating auto option, it generally solves the penetration problem but sometimes it can result in problems due to movement of nodes in near by regions also.
    Kindly check this and if elements are less in penetration you can go for manual correction also.
