Dear users!
I have one problem when solving static analysis of 2D plate model
As you can see, the setting of analysis with 3 components Var 6-1, DS, Var6-3. Everything seem be fine because the process of solving is done without any warning.
But when I open results analysis in hyperwork, only component Var6-3 appear, the other 2 components DS + Var6-1 disappeared from result.
Can you please give me some suggest for this problem?
Thanks you in advance!
