auto contact did not create contact elements between all of the surfaces within the proximity range. What could be the issue
Hi @Suganya Kanniyappan
Do you see any warning or error message while using auto contact?
Can you try and create different contact surfaces for different regions?
Auto contact is approximating based on the angle and distance and creating partial contacts,
Thank you
