hi expert,
i found a new feature in InspireForm 2021 related to convert HyperForm material into InspireForm.
how can i access this script? do you have any demonstration for this?
Thanks!
Hi
In your Inspire Form installation folder, some similar to
<installation_folder>/InspireForm2021\hwx\plugins\freedom\profiles\c2f\scripts\material
you may find the file:
ConvertHFMaterialsToIF.tbc
It is a compiled tcl script.
Easier way ito use, it s to call this script thru Hypermesh , "File>Run>Tcl/TK script "
A panel like figure below will open
You look for the HF material database, likely in the <Installation_folder>\hwdesktop\hm\scripts\hyperform\onestep
and select where to write out the xml material data.
Hope this is helpful
Regards
Hi In your Inspire Form installation folder, some similar to <installation_folder>/InspireForm2021\hwx\plugins\freedom\profiles\c2f\scripts\material you may find the file: ConvertHFMaterialsToIF.tbc It is a compiled tcl script. Easier way ito use, it s to call this script thru Hypermesh , "File>Run>Tcl/TK script " A panel like figure below will open You look for the HF material database, likely in the <Installation_folder>\hwdesktop\hm\scripts\hyperform\onestep and select where to write out the xml material data. Hope this is helpful Regards
Hi Rogerio,
Thank you so much for your very detailed answer.
Very nice!
