Talking about a permanent magnet synchronous motor.
What is the relationship between velocity of the motor and sound pressure level (dB) measured?
Are you looking to perform vibration & acoustic analysis using Altair Flux and OptiStruct?If so then you can refer below webinar from resource library for Altair Multiphysics.
https://altairhyperworks.in/ResourceLibrary.aspx?keywords=&industry=All&product_service=All&category=Webinar Recordings&order_by=date_created&order_by_da=desc
