Hello Guys,
I want to reanalyse my results from a topology optimization. As the part has thick walls, I don`t want to calculate with a surface-mesh. Is it possible to do a reanalysis with solid-mesh? (If yes - how?)
Thank you
Cheers
I managed to Reanalyse the model with Post->OSSmooth->FEA-Analysis. However I wasnt able to start the calculation because hypermesh is writing the error shown below.
Any suggestions how I could fix this Problem?
Thank you.
Hi @ElZett
Looks like the issue is with the IDs.
Please Go to Tool page>>Renumber>> select all nodes and renumber.
You can provide a start number with say 10K
