ERROR IN INPUT FORMAT DESCRIPTION : IN BLOCK : 1005795
Updated by Altair Forum User
We are doing rollover analysis and we are facing issue related to this error...will you please help us to find out our mistake and to correct it...? here by I have attached .out file, model checker image and error image..please go through it and suggest us what should we do to remove it.
1 - 3 of
31
Sir I have already updated all 1d and 2d element type and already shsred my mofel in your dropbox
Update the element types especially for the 1D elements. In the model you have sent most of them are not updated and it seems like the same throws this error.
If this is not helping please share the latest model file as in the old one there are some components without any mat/prop.
Is this model converted from any other solver format?.
Can you try updating the elements (2D page>>elem types>>select all elements for 1D and 2D options>>update all).
If the issue persist please share the model file through the secure dropbox link.
