I am trying to use shell element in a crushed cylinders only outer surface.
I am getting the following error
ERROR ID : 274
** ERROR IN RIGID BODY DEFINITION (INERTIA)
DESCRIPTION :
-- RIGID BODY ID : 1
-- RIGID BODY TITLE : rigid mass
RIGID BODY HAS A NULL OR NEGATIVE INERTIA
Also i when i check element type using 2d i am getting value has 108 what does that mean. I wish to use a shell element. I have put it in the picture.
2) I wish to use only a single layer of shell element for the 3d igs model i have imported but a general 3d mesh can be easily done. Is it possible for only a 2d mesh directly rather than the procedure i did by not selecting another side.
yours sincerely,
kartik kanugo
