Submitted by linklessa on Fri, 11/06/2009 - 22:19
Hi. I'm working with a eZdsp F28335 from TI. I want to simply test a output by a GPIO, but when i configure the digital/analog output, there are no responses. I used the blink283x example, and noted that the output block that controls the LED blinking is configured: Digital, Channel 0, Port B, Bit Width 1, Target Board 0. In the manual, the GPIO pin that controls this same LED is GPIO32!
How can I configure the output blocks (and other necessary configurations) to get a output signal in a GPIO 0, per example?
