When setting up a lattice optimisation you have a 'Mindim' option which when selected and export appears as MEMBSIZ in the solver deck. What does this so and how does it compare to the lattice parameter MINRAD?
Thanks,
Tom
Mindim is the member size that allows controlling the minimum and maximum member size in an optimization.
You can refer to Member size control on OptiStruct help for more information.
