<?xml version="1.0" encoding="UTF-8"?>Finding error for running the radioos analysis
Hi Yash Gaikwad
The error is because the slave nodes cannot detect the master segment.
The master segment is found via 2 formulations:
Change the Isearch formulation to 'old segment' and this the analysis will run without any error.
Go to Tools > Model checker to check for other errors.
Check online help for more details regarding Tied 2 interface and formulations.
