Hi everybody,
thank you for accepting me in the forum, this is my 1st post but i hope will follow others for helping someone and for asking your help.
As mentioned in the title, I'm making some exercises for understanding better FEKO but looking around examples and forum posts I didn't find answer to the following problem: how I do represent in FEKO an antenna made of rigid aluminum telescopic elements (tubes)?
By using connected wires with different radius? By using connected cylinders, also woth different radius? Or there is a different way?
Telescopic elements have difference resonance frequency and impedance compared to singolar radius ones, so the different configurations should be took in count.
What do you suggest? Is the mesh managed better in one or both cases?
Thanks in advance for you kind reply,
Kevin
