hello guys,
I am getting a trouble while performing a simulation on HM-CFD-AcuSolve.
The simulation in this case is Natural-convection (Acu-3000 in AcuSolve tutorials).
when i completed on AcuConsole (following tutorials), the result was OK.
But when performing on HM-CFD, the heat from the inner solid does not transfer to the surrounding area (air). So the simulation falied.
my version is Engineering solutions 2017.3 and AcuSolve 2018 (downloaded from Altair connect).
I tried to check on .INP file generated by both software (AcuConsole and HM-CFD) for the differences but no result.
i also add the following command to .INP file (HM-CFD) to make sure the surface transfer heat:
wall_function_heat_flux_factor = 1
but nothing work.
Does anybody know about this situation?
please help.
Appreciate. Thank you!
P/S: the HM-CFD file is in attached, either the AcuConsole database (.Acs). please view and help me.
