I unknown the problem of my model because it haven't error, but it have some warning like in this picture
Hi @Nguyen Thu Khoa
Looks like the problem is the material and property compatibility and also small strain formulation is activated on TYPE14 property which may not be compatible with the analysis you are running.
Can you please share more details about the analysis?
