Hi all,
After topography optimization, how can we get the optimized geometry by using hypermesh? How to use OSSmooth panel?
Roy
Please refer attached document on Topography optimization with OSSmooth usage.
Hi @Rahul R,
Thank you for the document. What's the meaning of 'threshold' an 'layers' parameter in OSSmooth panel under below? How to understand it and how to set the right values for them?
Anyone can explain this two parameters?
