Contact Verification
Altair Forum User
Dear All,
Could you help me to verify, is my simulation valid or not?
I do not know because this is first time I use contact in hyperworks
my material is steel, with mechanical properties :
1. E = 205000 MPa
2. Poisson Ratio = 0.29
3. Density = 7.85E-6 kg/mm3
4. Yield Strength = 490 MPa
5. UTS = 686 MPa
The .hm files is in attachment.
Thanks and Best regards,
Iron_Man
Stick, Slide contatcts are generally not recommended for linear static analysis.
In your case it is OK for now, but prefer using freeze instead.
0 -
Thanks for your answer
About type of contact I have chosen in my simulation, I will evaluate again.
Iron_Man
