im getting remaining time as *****. please find attached image. what causes this??
Hi Guru,
Please check the unit consistency in the model.
If they are correct and if this issue persist please share the model file.
This is due to the very low time step in the model. After running for some time you can see that it shows the remaining time for the run,
I have sent you the updated files.
