Hello experts,
I am tending to use IS Cast to simulate a casting process of a golden ring.
In real-life, they usually made rings by using Vacuum machine for gravity pour casting or rotating machine for centrifugal casting.
My questions are:
1. Is it possible to define vacuum pressure in IS.Cast?
2. Can i use gravity-tilt process to simulate the centrifugal casting?
3.Will these features be add to IS Cast in the future?
Thank you very much!
