I've run a free-sizing optimization on a formula student monocoque. I set some parameters for the core material, for it to be max 12.5mm and in steps of 2.5 mm manufacturibility.
When I have a look at the xxx_des.h3d I can see that the thickness of the core in some areas is 12.5mm (my model is in meters).
However, when I import this model into a new model (with import-solver deck), the thickness of the core plies are not even close to 12.5mm in total. What is causing this behaviour?
I attached 2 pictures to clarify.
Thank you in advance
Alex
