Hi there,
i tried to model a linear buckling analysis with an unsymmetric T - extrusion. The solution is far away from the solution calculated with hand:
HM solution with load applied to the shear center: 5543 kN
HM solution with load applied to the extrusion center: 5543 kN
Calculation by hand: 8980 kN for euler case 2
Calculation by hand: 2328 kN for 'drill-buckling' (don't know how this is called in english-> german: Biegedrill-Knicken)
So why the solutions are so off and why the solutions for shear- and extrusion center are the same? If the load isn't applied to the shear center the unsymmetric extrusion should also drill-buckle which leads into much less buckle load.
I added the 2 FE-models (shear center and extrusion center)
Thank you for your help
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
