I tried doing 3pt bending impact analysis which is featured in radioss tutorials.
When I run the analysis,
it is showing ,
error id 126
-errorin material input.
Kindly help me out
Hi Vinoth,
Please check the inputs provided for the material, especially honeycomb material.It seems like you have missed something.
If you are not able to trace it then please share the model file.
Thanks for the response sir.
I tried solving the error, I am unable to clear it.
i attached the Rad file., kindly check this out and explain the error cause.
thank you.
The corrected file is attached along. The issue was with the /MAT/LAW36.
Ok thank you,
But what was the issue ? how did you solved it sir?
