Weld elements are deleting in my Model whille running the Radioss model
Weld elements are deleting in my Model while running the Radioss model.
Its keep on showing the same error msg of deleting the same weld elements. please check the below msg.
93310 45.70 0.4975E-03 NODE 22049723 -2.5% 0.2414E+06 0.1032E+05 262.6 -2919. 0.2983E-01
-- RUPTURE OF SPRING ELEMENT NUMBER 13507551
-- RUPTURE OF SPRING ELEMENT NUMBER 13507539
**WARNING MINIMUM TIME STEP 0.4623E-05 IN INTERFACE 11(DTMIN= 0.2000E-03)
REMOVE SLAVE NODE 10291983 FROM INTERFACE 11
93320 45.70 0.5161E-04 INTER 11 1.7% -0.3218E+05 0.1180E+06 0.1771E+06 -2918. 0.3080E-01
Hi Sudhakar,
Did you mention any rupture criteria for the spring elements?.
Can you share the model files (starter and engine)?
