I am trying to insert manually a drape table and then have it mapped into the elements. So far I have tried to make a SET of nodes (SET_GRID), and point the drape table to this SET, but it is only modifying the direction of one element. Actually, this is a simplyfied example, what I really need is, in a more complex surface, import points (with coordinates) and directions(with vectors) to indicate the plies' orientations. Is it possible?
Thanks in advance,
Rosa
