I try to connect 3-D mesh element and 2-D element by 1-D weld connector.
just want to transform load and displacement from one part to another part.
The weld property are not available.
which type of connector should prefer.(rbe2 and rbe3)
RBE3 typically used for load transfer. RBE2 elements may give stiffer results.
