dear all,
i have defined S2S contact with static coefficient of friction 0.1.
roller edge is penetrating inner ring edge.
how can i resolve this issue.
Hi
Can you try with STIFF on PCONT?
This may help remove penetration but it may structure stiffer if you provide very high value.
Start with a value of say -100 and check the results.
Dear Prakash,
please suggest any corrections.
Can you try with PCONT and use STIFF and Mu1 to provide static friction and check if that helps?
