Currently I'm trying to optimize a composite laminate in optistruct. I have meshed the surface I use as shape. When I try to apply a pressure force on this surface the pressure is applied on both sides of the surface. This results in an displacement of 0 mm, ofcourse....
so: How can I apply a pressure force on a single side of a surface in Normal Direction?
