I have a wired issue (see image): I apply a rigid body to the upper surface with a master node in the center or rotation (COR). I then apply a moment in XX to the master node. I further constraint the master node so that it only has one DOF around the X-axis. However, the result is not a bending motion but rather a minimal torsion without much moving. I tried a whole punch of settings and it never really works. Is there an issue with the RigidBody?
Thanks in advance!
